PostPosted: Tue Aug 25, 2015 9:19 am
When allowing 32 bit input for the Winamp/DSP plug-in but feeding it with something different, e.g. 16 bit, what happens considering bit depth?
  1. Does the host or ST convert the 16 bit to 32 bit? Maybe there's even a second conversion from integers to float in ST?
  2. What bit depth does ST output? (I can choose different output bit depths in the host but again I don't know if ST or the host is doing the conversion.)
The idea is to minimize the number of conversions assuming mainly 24 bit input and sometimes 16 bit.
PostPosted: Tue Aug 25, 2015 11:14 am
In ST everything uses 32-bit floats. So, there's one conversion to 32 bit float when coming in, and one back to the original format (with some simple dithering) when going out.
