 Post subject: Unreal Engine
PostPosted: Tue Jul 28, 2015 11:36 pm
- Only for FM!
- Loud!
- "That" bass!
Unreal Engine_014C_FM.sts [90.74 KiB]
Downloaded 535 times
Unreal Engine_015c_FM.sts [90.87 KiB]
Downloaded 561 times
I need to know is everything ok to make it final.
Be sure to use latest ST beta. (v7.71beta18+)
Enjoy!
 Post subject: Re: Unreal Engine
PostPosted: Thu Jul 30, 2015 8:02 pm
Wich ST version? :)
PostPosted: Thu Jul 30, 2015 11:24 pm
Wich ST version? :)
PostPosted: Fri Jul 31, 2015 1:50 pm
I have a question. I use ST on a machine that encodes to the web and then another machine that pulls a feed from that encoding machine which is at another location which has the transmitter that also has ST on it. The transmitter option is also active on it also. Would that be double encoding using the same sts file at both locations? would that be a wise thing to do?
PostPosted: Fri Jul 31, 2015 9:43 pm
Kickass preset! :)
Bojcha for president!
Greets Jeff ;)
Garbage in is Garbage out !
PostPosted: Sat Aug 01, 2015 7:24 pm
Wich ST version? :)
o.O
Did you have write that before or after my post? :o
Man, think I need to get some beach :D
PostPosted: Sat Aug 01, 2015 7:33 pm
New version.
Done some cleanup.
PostPosted: Fri Aug 07, 2015 10:11 am
Please read this:
http://thimeoaudio.blogspot.com/
