PostPosted: Tue Jun 09, 2015 4:23 pm
Is there a way to have ST start with the current or last settings used with the VST plugin. Or is there a way to have that set?
PostPosted: Tue Jun 09, 2015 4:31 pm
In case of the VST plugin, the VST host should take care of that... It should store and reload the settings when you restart it.
PostPosted: Tue Jun 09, 2015 6:09 pm
yes the host starts back with ST loaded but not with the settings it was playing last
PostPosted: Sat Jun 13, 2015 2:07 pm
Which host is it? Can you contact them about this?
Btw - the NAME of the last loaded preset might indeed not be saved for a VST plugin, but the settings themselves should be.
PostPosted: Sun Jun 14, 2015 5:03 am
Radioboss is the host. ST loads fine. It's just the preset that doesn't get reloaded if it's the last one used.
