Hello all,
Attached are updated versions of the Smooth Ride preset. The 2MB version provides slightly more consistency than the single MB, but each has their use. For each, use the final clipper to adjust loudness and density to taste. "Out of the box" it is quieter than pretty much all of of the other presets. The choice is up to you!
I also decided to use my name since it's attached to this alias anyway, on other sites such as YouTube.
I merged Jesse G's ND settings. Personally, I leave it off. Again, the choice is up to you. If the settings do not sound right, just reset them to the defaults and re-save the preset.
I stuck them all in a ZIP file on my dropbox.
Cheers!
https://db.tt/XnzuD8L2
