PostPosted: Tue Jun 02, 2015 4:35 pm
I am using SA Stereo Tool 7.60 as a VST Plugin with Reaper 64bit (v4.78) on Mac OS X 10.10.3
and was wondering if there is a way to automatically load the last used settings file (.sts)?
It keeps losing it and I have to go into the Stereo Tool window and load it manually.
Hope somebody got a fix or is able to tell me what I am doing wrong?
PostPosted: Tue Jun 02, 2015 5:52 pm
Hm... Reaper should actually take care of that (by getting and setting all the VST settings).
PostPosted: Tue Jun 02, 2015 6:31 pm
Sorry, I messed up something :roll:. My intention was to refer to the PNR settings.
It seems that they are going back to default with every launch.
PostPosted: Tue Jun 02, 2015 6:33 pm
Ow yes, that is true. I still have that on my todo list.....
If I save them via the VST interface like all the other parameters, then the size of the parameter list will more than double, which some VST hosts can't handle.
What I really need to do is change to a different VST parameter format. Which takes time...
PostPosted: Tue Jun 02, 2015 7:08 pm
Thanks for the really fast reply.
Any idea how long it will take?
It would be really helpful for some interviews I am working on.
I could use the command line tool but the raw material is in 24 bits and as far as I know the command line tool only supports 16 bits.
So it would be really cool if you could boost the priority :D
If you need somebody for testing stuff (Reaper on Mac) just let me know!
PostPosted: Wed Jun 03, 2015 3:10 am
It's not specifically MAC related... On a PC in VST they also aren't saved.
This won't be fast, the next month I probably won't even have time to work on Stereo Tool at all... I think it can easily be next year before I have time for this.
