Post new topic  Reply to topic  [ 53 posts ]  Go to page 1 2 3 4 5 6 Next
PostPosted: Mon Jun 01, 2015 9:21 pm
Jesse Graffam - Minnesota
UPDATED for Stereo Tool v9.21+
Here's my first public Stereo Tool preset. This preset is inspired by my time as a boy living in the natural beauty of the woods of Minnesota USA.
Nothing was done to the multiband AGC settings to compromise the spectral balancing abilities in order to "hide" incorrect action within distortion, unlike almost all presets that I've heard for any processor. This is extremely challenging to achieve for any processor no matter how it's adjusted.
This preset is calibrated for -24 LKFS / 0 LU input loudness. If you send it louder audio, the input AGC will protect against really bad things happening, but one of the main design goals with this preset is to have zero sound of wide-band compression. If you are running too much loudness into Stereo Tool, you may end up hearing the operation of the AGC. Please visit EBU PLOUD for more information.
The preset comes with HD (also for Streaming), and FM settings for 75uS and 50uS emphasis.
You MUST use Stereo Tool v9.21 or later or this won't sound correct.
Please read the next post for the download links.
Thanks for listening :)
- Jesse Graffam
Downloads
Minnesota v0.03.31 Beta for Stereo Tool v9.23
HD: https://www.dropbox.com/s/6ikzq82wgv18e ... 1.sts?dl=1
Old Versions
Minnesota v0.03.30 Beta for Stereo Tool v9.21+
HD: https://www.dropbox.com/s/89amuc4vm9le2 ... 0.sts?dl=1
Minnesota v0.03.29 Beta for Stereo Tool v9.21+
HD: https://www.dropbox.com/s/udc3vce1y1mbv ... 9.sts?dl=1
Minnesota v0.02.80 Alpha for Stereo Tool v8.01 BETA 48
removed/depreciated
Minnesota v0.01.57 Alpha for Stereo Tool v7.74+
removed/depreciated
Minnesota v0.01.56 Alpha included with Stereo Tool v7.70-v7.73
Reserved
PostPosted: Mon Jun 01, 2015 9:57 pm
PostPosted: Tue Jun 02, 2015 12:00 am
Cool!
PostPosted: Tue Jun 02, 2015 9:34 pm
These are amazing! Thanks for sharing 8-)
PostPosted: Wed Jun 03, 2015 6:16 pm
Thank you Jesse!
PostPosted: Wed Jun 03, 2015 6:29 pm
Thanx Jesse twin city is a great one!
Garbage in is Garbage out !
PostPosted: Wed Jun 03, 2015 7:14 pm
Nice and unique sound JesseG, congratulations. But I've found a bug?? Minnesota Twin Cities FM and Minnesota Norht FM have disabled the bandpass.
https://fmfeeling.com
PostPosted: Thu Jun 04, 2015 7:55 am
Hmm and the v7.70 final has already been compiled. I'll have to see where that happened at, because a couple changes that don't effect sound were done by Hans. It's probably my fault though.
The high-pass settings remove some processing artifacts from Stereo Tool so that's important for all versions. Thanks to Bojan for that tip.
