 Post subject: Before i order...
PostPosted: Thu Jun 18, 2009 10:23 pm
Hey there,
Just stumbled upon Stereo Tool today completely by accident! However all last week i was looking for an audio compressor/limiter and i'm so glad I found it.
A couple of questions first before I order.
1. Can stereo tool work it's magic on from a live "line-in" input and output that to the soundcard.
2. If not, If i were to set up a local shoutcast server and stream to that, could Stereo Tool pick up the stream and output the compressed version to my soundcard output.
Thanks, hope to hear from you soon! :)
Dave
 Post subject: Re: Before i order...
PostPosted: Thu Jun 18, 2009 11:08 pm
Hey there,
Dave
1. Yes. Use the stand alone version. That version reads the sound card input and sends it to the sound card output.....
2. If you use a program that supports Shoutcast input and either Winamp DSP plugins or VST plugins, that should also work. Winamp would do fine.
So both options are possible - the stand alone version is probably the easiest solution (and it will give a better output quality, because there's no MP3 compression in between).
Of course you can try if it works before you buy it.
PostPosted: Thu Jun 18, 2009 11:44 pm
Hey hvz,
Well i downloaded it and gave it a quick go.. and i love it! :) I believe that you are a genius!
I'm formatting a computer now to try it on there and if it works with that CPU & memory etc i'll be placing an order!
Thanks,
Davey
