 Post subject: Input level tweak
PostPosted: Wed Mar 05, 2014 6:53 pm
One feature I wish ST had is the ability to balance the input levels. Just a couple of dB range would be nice.
To change the subject... I really like the way 7.4 sounds on the air! Keep up the great work!
 Post subject: Re: Input level tweak
PostPosted: Wed Mar 05, 2014 11:57 pm
Does this mean that your system is stable now? If so, what did you do?
PostPosted: Wed Mar 12, 2014 4:34 pm
Sorry for the delayed reply, but I have nine radio stations to keep an ear on!
The Trace Alpha sound card has been performing well. I never did calibrate the output for minimum overshoot. That's not a big deal to me at this time. There is one song that sounds awful on the air,but I haven't been able to listen to it before it hits the processing. I had the title written down somewhere but can not find it as I type this. Otherwise, things are great!
The unknown song in question sounds like it has severe multipath issues when I hear it in the car. Haven't been able to listen to it on a stationary receiver.
PostPosted: Wed Mar 12, 2014 7:50 pm
I meant the hangups! About multipath: are you using the Composite Clipper with either Multipath Clipper or Stokkemask enabled?
PostPosted: Fri Mar 14, 2014 7:31 pm
Here you are...
By the way, the song that sounds bad is " I'll Follow You" by Shinedown.
Any suggestions or comments are welcomed.
PostPosted: Sat Mar 15, 2014 9:25 pm
By the way, the song that sounds bad is "Follow You Down" by Shinedown.
What is bad with it? With what preset? I or anyone else would need preset you used to tell you more.
I downloaded track... more or less sounds nice here. Well processed with any of mine presets.
edit:
How this sounds? http://www32.zippyshare.com/v/3421057/file.html
PostPosted: Mon Mar 17, 2014 2:16 pm
That sounds better. The part that starts around :40 seconds and continues for a little while is the part that sounds like wicked multipath.
The preset I use is B-Town, modified quite a bit.
Please feel free to critique what I've done. I'm not a tweaker at your level.
Phil 5.sts [50 KiB]
Downloaded 461 times
PostPosted: Wed Mar 19, 2014 6:03 pm
Things must be busy in ST land!
PostPosted: Sun Mar 23, 2014 2:13 am
No answers yet...
PostPosted: Sun Mar 23, 2014 3:41 am
O..
I can tell you this. Don't use that preset :)
That one uses old multiband and it was maded to be answer fro upcoming Omnia.11 in that time.
Depend on what sound you like I can recommend "J-Type" with bit more pushed Advanced Clipper.
That should give you much details and competitive loudness.
If you are looking super compressed preset then i cant help much.
Also, if you are interested, i can give you my latest preset with 6 bands where everything is maximaly contolred from multiband. Yet, i would need to build FM version - that should go quick.
