 Post subject: IGNITION
PostPosted: Thu Feb 20, 2014 10:42 pm
Aggressive processing for CHR.
Tuned in VST with Reaper.
Used the 2013 HOT 100 as my working set (HQ CD source).
note: AGC was tuned to become active only with the very highest RMS inputs, as a distortion limiter.
I did not see it necessary to use the AGC as a constant rider for level; I use multiband for that instead.
If you use normalized high quality source, this should be fine.
IGNITION.sts [48.69 KiB]
Downloaded 456 times
 Post subject: Re: IGNITION
PostPosted: Sat Feb 22, 2014 9:41 pm
UPDATED:
The MAIN AGC leveler is disabled by dropping the attack to 0.
However, the COMPRESSOR at the end of the AGC (blue meter), is slightly more active now; used for smooth leveling.
Multiband needed to be retuned to compensate and to improve consistency and loudness.
Phase rotator redone.
used the same working source as previous
IGNITION_2.0.sts [51.02 KiB]
Downloaded 488 times
