 Post subject: Simple 5 Band
PostPosted: Sat Feb 01, 2014 5:58 pm
This is a simple setup. A 2 band AGC, 5 band peak compressor/limiter, with a simple clipper at the end.
File comment: Peak Multi Band
PMB.sts [46.42 KiB]
Downloaded 507 times
 Post subject: Simple 5 Band RMS
PostPosted: Sat Feb 01, 2014 11:02 pm
This is a simple setup. A 2 band AGC, 5 band RMS compressor/limiter, with a simple clipper at the end.
File comment: RMS Multi Band
RMB.sts [46.49 KiB]
Downloaded 495 times
 Post subject: Update: Simple 5 Band
PostPosted: Sat Mar 15, 2014 8:33 pm
The PMB was updated to a harder knee on the compressors to increase density and reduce limiting. Both versions have a change in the Bass Boost to a lower frequency before gain.
File comment: RMS Multi Band Updated 2014-02
RMB.sts [46.49 KiB]
Downloaded 497 times
File comment: Peak Multi Band Updated 2014-02
PMB.sts [46.43 KiB]
Downloaded 440 times
