PostPosted: Wed Dec 25, 2013 4:28 pm
I am using the command line version (stdin / stdout) of StereoTool for sound processing in my hobby homebrew music application.
When I'm using 7.40, I hear regular clicks going on, roughly every 1/2 second. Especially when the music is getting a bit louder, as if a silent sample is being sent every buffer fill. This problem wasn't there in version 7.31.
If required, I can investigate this problem further, but it's time to celebrate christmas now, with music enhanced by stereo tool 7.31, merry xmas by the way :)
PostPosted: Sat Jun 21, 2014 11:32 am
I still have the issue in 7.42.
Here I added some sample files (raw stdout output of stereo tool, but with wav header added):
http://musicmaniak.net/downloads/temp/o ... md_731.wav
http://musicmaniak.net/downloads/temp/o ... md_740.wav
http://musicmaniak.net/downloads/temp/o ... md_742.wav
You can clearly hear that versions 740 and 742 add clicks, while 731 doesn't.
I used Bojcha's Addiction preset for all three of them.
PostPosted: Mon Nov 03, 2014 7:26 pm
I finally solved this problem. :D
I introduced a variable that showed the difference of the number of bytes I sent to the stereo tool process, and the number of samples I received from it.
This difference became larger in time, stereo tool seemed to throw away samples!
So I was sending audio in whatever amount the sound card buffer was needing. This seems to cause trouble in the Stereo Tool process. I always got the audio in chunks of 65536 bytes, and it seemed the rest was discarded. Maybe it's a maximum inputstream buffer size of Java, I don't know.
But I got rid of the issues by buffering up the audio, and sending them in chunks of 4096 bytes.
