Anyway, feedback:
CPU load reduction by coding for actual usage rather than each filter in isolation...
I was indeed thinking a few days ago that I hadn't heard from you yet about the CPU load reduction! On my system the last few versions have a considerable drop in CPU usage (for example, in version 7.40 the compressor/limiters and also Natural Dynamics uses more than 30% less than in version 7.31 - total CPU load is about 13% lower for FM presets with composite clipper, so the heaviest presets). So, I would expect that now the new compressor/limiter uses about the same as the old one, maybe even less. Please let me know
I do have this point on my todo list:
50. Add a mode where all multiband filters (Natural Dynamics, Noise Gate, Multiband Compressor, Stereo Boost) use the same bands, and they only need to be split up once. I'm not too sure that the Noise Gate can be included in this list...
This will only work for a limited number of cases (bands must be the same, for Stereo Boost the 'Remove excessive reverb' must be turned off etc.)
Actually, originally the Multiband Compressor and Stereo Boost were combined... But I have created a new multiband compressor and Stereo Boost was built into the old one, which means that part of the old multiband compressor code is still in use. I'm planning a new stereo widener anyway, so I'm not going to merge it with the new compressor at this moment...
