 Post subject: i need your opinion
PostPosted: Sun Dec 22, 2013 2:42 pm
hi mates i want if it is possible to hear my radio and tell me your opinio about my sound here is the link
http://74.118.195.192/tunein/crashrad.pls
Thank you in advance !
 Post subject: Re: i need your opinion
PostPosted: Sun Dec 22, 2013 3:06 pm
very unnecessarily loud and clipped.
http://i.imgur.com/vrL98w5.png
PostPosted: Sun Dec 22, 2013 3:09 pm
thank you bojcha!
any suggestions to change it ?
PostPosted: Sun Dec 22, 2013 3:13 pm
Well.. listening more i see that there is like no processing at all..
It Realy depends what type of sound you like and what you expect from processing.
I can recommend you x-mas preset. At least start from there..
PostPosted: Sun Dec 22, 2013 3:59 pm
first af all i realy appreciate your help!!
i load xmass preset and i think my sound is very good now ! please listen it and tell me your opinion !
PostPosted: Sun Dec 22, 2013 8:06 pm
Very bad. Load preset and do not touch anything. If you dont like it, choose other.
Or you might doing something wrong. Still sounds like not processed.
