Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
PostPosted: Sun Oct 27, 2013 11:25 pm
7 inch touchscreen with hdmi would work if your mb does hdmi, but the monitor is more expensive.pm leif and see where he got his..lol
PostPosted: Sat Dec 21, 2013 8:49 pm
why dont you use one of these:
http://www.ebay.com/itm/Kontron-1U-rack ... 485e746c0d
and use a rack case for your ST pc ?
PostPosted: Sun Dec 22, 2013 12:03 am
@oldiesstation: If you buy them in China in large quantities the price goes down a lot (if you buy 500 you can probably get them for $30-$40 a piece). I don't know how the quality is though...
PostPosted: Sat May 24, 2014 11:29 pm
I make a start whit a own case with a 7 inch toutchscreen
http://imgur.com/fNktuhO
PostPosted: Tue Feb 14, 2017 8:37 pm
Does anyone have a dv700 mounted in a rack? If so, do you need a deeper rack or does it clear the back and hang out the back given that its 17.5 inches wide.?
Thank you
ofloxacin and ornidazole
