Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: X-T4sys by GAP
PostPosted: Sun Nov 10, 2013 4:13 am
For my personal use I modified it in a more mellow way, I think.
Smooth ... same spirit! ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Thu Nov 14, 2013 6:05 am
Two major changes in this new version:
- MB and SB now have Traditional Detection RMS, instead of RMS. Times and levels are adjusted.
- ND (experimental) 3 band, but only act end bands (Bass and Highs), the mids are not affected.
Test in Last Beta 15. ;)
GAP_X-T4sys_v0.6.sts [57.25 KiB]
Downloaded 239 times
by GAP
PostPosted: Fri Nov 15, 2013 1:40 am
Here's a 9-band ND and some declipper for ya. It made the bass a tad bit punchier. Too hot for my personal tastes. Nice work.
GAP_X-T4sys_v0.6dew.sts [45.73 KiB]
Downloaded 232 times
PostPosted: Fri Nov 15, 2013 4:30 am
I regret that my cpu can not with all this ... thanks anyway. :(
This preset is hot, as the name ... :)
by GAP
PostPosted: Fri Nov 15, 2013 4:33 am
Version adapted to the new Beta 16 and new RMS, for my taste is better. ;) Thanks Hans.
GAP_X-T4sys_v0.7.sts [56.87 KiB]
by GAP
PostPosted: Sat Nov 16, 2013 10:06 pm
Version adapted for beta 17.
Highs better. ;)
PS: Do not use previous presets with Beta 17, may not properly set RMS mode, and sound bad.
GAP_X-T4sys_v0.8.sts [57.49 KiB]
by GAP
PostPosted: Tue Nov 19, 2013 4:22 am
Following testing in the new mode RMS and integration times, a new version, with a sound a little more open, clean and dynamic. ;)
For Beta 17.
GAP_X-T4sys_v0.9.sts [57.48 KiB]
Downloaded 254 times
by GAP
PostPosted: Thu Nov 28, 2013 4:12 am
Some changes, mainly in the clarity of the highs (SB, EQ, MB Mix). ;)
For Beta 20.
GAP_X-T4sys_v1.0.sts [57.21 KiB]
Downloaded 262 times
by GAP
PostPosted: Thu Dec 12, 2013 4:16 am
Adapt for Power Bass, use Beta 25. ;)
GAP_X-T4sys_v1.1.sts [57.86 KiB]
Downloaded 225 times
by GAP
PostPosted: Tue Dec 17, 2013 4:12 am
Update for beta 27.
Some changes, for best y power sound! ;)
GAP_X-T4sys_v1.2.sts [58.04 KiB]
by GAP
