 Post subject: SCA Inputs
PostPosted: Wed Jul 24, 2013 8:02 am
Hans,
I have an input of 48kHz sample rate on the main audio input to ST and have that Card's Output set at 192kHz for MPX. I am using another card (same type Juli@) for SCA 1 Input (67 kHz). If I run a 48kHz signal into that card do I need to set the sample rate of that card at 192kHz as well, or 48kHz? As it really doesn't have an output (as such) as the SCA is put into the MPX output on Card 1 I am not sure what that card should be set at.
Regards,
Clipper
 Post subject: Re: SCA Inputs
PostPosted: Wed Jul 24, 2013 4:45 pm
It probably doesn't really matter as long as it works. Ideally you would connect the clocks of the 2 sound cards (in hardware!) and then they have to run at the same sample rate.
PostPosted: Thu Jul 25, 2013 3:03 am
Thanks Hans.
I am getting unreliable results and as there is no documentation I thought I might have been doing something wrong in the way I am setting it up. We couldn't figure out whether we needed to give the SCA input a higher sample rate or whether 44.1 or 48 input was sufficient.
We'll investigate further.
Clipper
PostPosted: Thu Jul 25, 2013 4:20 am
What are those results? If you can tell me what's wrong I might have some ideas.
