PostPosted: Sun Jul 07, 2013 10:17 pm
The Azimuth parameters seem to have disappeared between v7.03 and v7.23 in the VST plug-in. They load from a preset, but I can't figure out how to view/adjust them.
In v7.03 the Limit and the Change Speed are below the enabled bar. In v7.23 only the grid shows below the enable bar.
Thanks!
PostPosted: Mon Jul 08, 2013 1:19 am
Ah! Try this: Configuration -> Operating mode. With 'Extreme tweaker' you'll see everything (including things that you should probably never touch). By default it's set to 'Basic', in that mode only the most important settings are available.
PostPosted: Tue Jul 23, 2013 5:16 pm
Thank you--that helped a great deal!
PostPosted: Tue Aug 13, 2013 2:06 am
True.. but at default (reset) settings, azimuth does not have any settings. So, or default should be added or settings should be visible in any mode.
