 Post subject: Sparkle FM MPX LD
PostPosted: Sat May 25, 2013 8:12 am
General purpose low delay preset. It's made for 75us so it might not take full advantage of the extra HF headroom that 50us offers when used in 50us. 77% quality is intentional. 100% sounds cleaner but also duller.
-Requires MPX clipper because otherwise it won't "sparkle".
-Uses multiband burst protection as a second multiband stage
For ST 7.60 (preset v7.1): You may want to set FM transmitter lowpass to 16400Hz or disable it (preset is already lowpasased at 16400). It make a difference in clarity for me.
For ST 7.60 (preset v7.1) 75us: Please uncheck Advanced Clipper > Distortion > Reduce IMD Voice Vibrations to improve transients and sibilants.
vmp94-Sparkle-FM-MPX-LD-v6.sts [49.66 KiB]
Downloaded 582 times
 Post subject: Re: Sparkle FM MPX LD
PostPosted: Fri Jun 07, 2013 1:16 pm
Could use more highs. I thought limiting the highs will reduce the artifacts but I don't seem to notice artifacts anymore so more highs it is. Should also sound clearer with 50us now.
7.1: enabled oversampled preclip for (marginally) better highs.
vmp94-Sparkle-FM-MPX-LD-v7.1.sts [49.67 KiB]
Downloaded 494 times
vmp94-Sparkle-FM-MPX-LD-v7.sts [49.67 KiB]
Downloaded 482 times
PostPosted: Fri Dec 20, 2013 3:09 pm
This version was made for ST 7.40. The mutiband behaviour has since changed and Sparkle v7.1 now sounds better on ST 7.50.
10.4: fix for new multiband behaviour
vmp94-Sparkle-FM-MPX-LD-v10.4.sts [54.96 KiB]
Downloaded 525 times
