Hello,
Thank you for your fast reply...
I´m from Germany therefore i have some little Problems with expression in english...
Of course the gating is necessary to prevent rising of "nothing" or extremly low level parts.
You are right, if the change in level is small the release time should be much slower than in bigger changes.
There you can allow more dynamics within a song and nevertheless you can be shure not to have such "wholes" because of the talent´s driving errors.
From Orban i´m very disappointed in this point, perhaps you will know it:
Their AGC has a definable window. You can define release times for in the window and out of the window.
The Idea is good, but they wanted to make soft change over between the 2 adjusted release times and have therefore inserted a constant delay before changing to the fast (ot of window) release time.
If you now have an element driven too high into processor followed by a song with low-level intro you have such a whole because it takes time for fastening up the AGC to the adjusted speed.
Regards,
Robert
