 Post subject: drz fat bass V3
PostPosted: Mon Mar 18, 2013 9:15 pm
sooo there we are again with our drz fat bass v3!
there's more compression on band 1 and 2 and that's the mostly changed part. while the wole sound is changed a little.
so let me know, v2 is in the beta's at webradio for if you want to make a watch to both :)
and while the v2 is in the beta's a v3 don't need more explaining :mrgreen:
mvg wouter
drz fat bass preset v3.sts [44.26 KiB]
Downloaded 646 times
 Post subject: Re: drz fat bass V3
PostPosted: Mon Mar 18, 2013 11:01 pm
found a little point, that i worked out to night, so made a little update to it, now its finished :mrgreen:
PostPosted: Tue Mar 19, 2013 9:43 pm
Uhm, are you aware that the release time of MB band 1 is set to 34 seconds?! I didn't notice it until I started loading several presets and yours sounded very bad, then I reloaded it and some others a few times and it sounded good :shock:
This goes for both of your presets!
PostPosted: Wed Mar 20, 2013 12:01 am
well i took a look on it and speeded up the release a little. so
hope it works better know for both :ugeek:
