PostPosted: Sat Nov 10, 2012 10:50 am
I checked your last version vst_stereo_tool_BETA633-035.dll as VST Effect in Wavelab 7 and it works fine in "live" modus but if I then would like to render my sound collage, the result is very fast but without stereotool audio processing. It is like that stereotool plugin will be not used during render.
This was not the case with all the older versions. My last working version 32-020.
My system: Windows 7 64bit and wavelab 7.2.1 32bit
PostPosted: Wed Dec 12, 2012 9:35 pm
so is it fixed in latest betas ?
