PostPosted: Sun Jul 08, 2012 12:05 pm
Well, i can't explain it so i made a screenshot - http://img24.imageshack.us/img24/951/92290600.png
With a few words, i want to use Lossy compresion with direct soundcard access, but ST says that FM processing is ON (but it's not as you can see)
PostPosted: Sun Jul 08, 2012 2:37 pm
Ow... Just out of curiosity: Why are you using Direct Sound Card Access? As soon as you turn the 'FM' setting it on part of the processing is changed to FM mode (among others, oversampling is used for clipping).
PostPosted: Sun Jul 08, 2012 5:03 pm
I use it, because i think it sounds a bit clear (i don't know why) maybe SAM Broadcaster is the bad guy :mrgreen: (And sometimes i use it in Winamp where i think it's necessary to use Direct Soundcard Access)
Anyway, it's not a bug, right?
PostPosted: Mon Jul 09, 2012 3:20 am
FM must be OFF
PostPosted: Mon Jul 09, 2012 5:38 pm
FM must be OFF
OK, i get it :mrgreen:
PostPosted: Wed Sep 26, 2012 4:27 am
I use ST (Winamp plugins) in RadioBOSS sound processing for FM and internet radio, for this I have turned on "enable directsound access" and with that the sound processor shipping with pre-emphasis, stereo and rds through a juli@ the transmitter board.
"Send to winamp", I have labeled "Normal Output", since that is the output that sends audio to output processed by Shoutcast.
the problem is that when the FM pre-emphasis is enabled "Normal Output", also has pre-emphasis.
The same applies to the version Standard Alone, when the output of FM preemphasis has activated, it also affects the normal outlets.
Sorry for my English, greetings!.
PostPosted: Wed Sep 26, 2012 8:57 am
@nelson c: I know, I intend to change this behavior in a future version. Not sure when yet though.
