 Post subject: Distortion problem
PostPosted: Tue Jun 26, 2012 10:23 am
I installed the stand-alone version of Stereo Tool (6.31). The audio is distorting almost all of the time, as if it was being played too loud. Clipping heavily, I think. Here is a screenshot I took where you can see that there are two bars going full red constantly.
I have tried lowering volume levels on many different places but I can't seem to locate the source of this problem. Any ideas?
 Post subject: Re: Distortion problem
PostPosted: Tue Jun 26, 2012 10:43 am
The plugin version works fine but I'm using Foobar2000 so I need the stand-alone version.
PostPosted: Tue Jun 26, 2012 10:48 am
Those bars show that the INPUT signal is too loud! So you need to lower the signal that's being sent TO Stereo Tool.
If you're using Line In, go to the sound card mixer settings and lower the recording level.
If you're using something like Virtual Audio Cable, my guess is that the player that you are using is distorted - or the recordings that you are playing are!
PostPosted: Tue Jun 26, 2012 10:56 am
I was actually using the sound cards "What U Hear" and lowering that volume fixed the problem. It was at 100 and I had to lower it down to 35.
PostPosted: Wed Jun 27, 2012 12:57 am
not good!
You are still looping signal!
PostPosted: Wed Jun 27, 2012 11:52 am
not good!
Yeah, but it was merely for testing purposes.
PostPosted: Fri Dec 07, 2012 5:43 am
You could potentially improve the quality a bit with Stereo Tool, but I think there must be software specialized at doing this. Basically the fading hiss background sound is fairly repetitive so it must be possible to at least reduce it a lot without hurting the audio too much. But not with Stereo Tool -it's made to handle a stream of audio, not to (probably with manual input) reconstruct a single file.
http://www.olivetcollege.edu/
www.test-king.com/onlinecourses/CFA-Level-1.htm
http://www.msu.edu/
http://test-king.com/cert-CISSP.htm
http://www.hodges.edu/
PostPosted: Mon Jun 03, 2013 7:10 pm
Newbie by here...
Some experience......
On Winamp, turn on the EQ, flat adjusments (0 dB all frequencies), and control the output to the ST with the "preamp slidder" until you get maximum levels with "no reds" on pre-amp bars at 0 dB ....Easy....
Regards for everyone.....
PostPosted: Tue Jun 04, 2013 3:30 pm
For those who use Winamp, I advise disabling the audio limiter activated by default comes, see attached image. ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue Jun 04, 2013 9:39 pm
And in same time winamp's preamp to max -1.0 ;)
