PostPosted: Tue Mar 17, 2009 5:39 pm
Hi
This should go on the winamp site probably, but that is so horrible I refuse to use it, so maybe someone can sympathize.
I am creating wav files on my PC and I need to get them to my laptop and put them into a permanent playlist so I am playing from the hard drive and not from CD.
I thought I could just burn the songs to CD and then copy them from the CD to the laptop, but not so fast. When I open the D: folder I get shortcuts to the CD itself and what is on the CD is now cda and not wav. Can someone help me out please?
Thanks
Phil
PostPosted: Tue Mar 17, 2009 8:13 pm
Audio CD's (which can be played back on a CD player) are different from data CD's. In this case you should write the data to a data CD. (There are programs to rip WAV files from audio CD's, but since audio CD's also have less data corruption protection I wouldn't go that route if it's not needed).
(Note: The CD's themselves are of course identical, just choose "Data CD" when burning).
In case you do need to rip files off an audio CD, I can recommend a program written by a colleague of mine: CDex.
PostPosted: Tue Mar 17, 2009 9:34 pm
So a wav file is treated as a DATA file? (hold on, let me get one of these smiling things. No, not that one. Let's try this) :o
So I can just open the folder and copy and paste the files into a playlist and they will play back in WAV format, is that right?
Thanks
Phil
