Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: naomi.one - preset
PostPosted: Mon Apr 30, 2012 1:36 am
naomi.one_rc1_web.rar [4.1 KiB]
Downloaded 1104 times
Preset for Stereo Tool 6.30. (web/home version)
Should be very constant and with plenty of (i hope) nicely controled bass. Also much bigger range/compression in MB, still sounds less compressed then other processors.
 Post subject: Re: naomi.one - preset
PostPosted: Tue May 01, 2012 7:05 am
good job! ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Wed May 02, 2012 4:31 pm
Adopted on live streaming from today, nice work
http://www.kanal80.net
Best 80's & 90's Music
PostPosted: Wed May 02, 2012 6:55 pm
thanks to both of you...
will upload new version soon (found some bad things)..
What stream software you use .. i think this 128k mp3 is not so good!
Also i think you need about 1dB attenuation on output.
PostPosted: Wed May 02, 2012 7:10 pm
Correct for the 1db atenu. i push it up to 0 maybe i shouldn't lolololol gonna put it normal -1.
For the streaming automation is a very good one " ProppFrexx ONAIR "
wayting for new update ;)
PostPosted: Wed May 02, 2012 8:05 pm
Don't know is it comming from encoder or you are playing like it.. 128k should be much better..
PostPosted: Wed May 02, 2012 9:59 pm
Something strange with the sound in fact... reverting to my old preset...
PostPosted: Wed May 02, 2012 10:16 pm
This has nothing with preset and processing, i am talking about bad mp3 files, or bad mp3 decoder.
PostPosted: Thu May 03, 2012 4:25 pm
A very good preset! Bass fascinating!
Good job
Thank you!!!!
PostPosted: Thu May 10, 2012 3:18 pm
Correct Bojcha found... Bad very bad encoder....(and of course somme bad mp3's) thanks...
