PostPosted: Sat Feb 04, 2012 5:05 am
IMO it could be sometimes useful to use very low FL pre amp multiplicators to calibrate the Multiband settings when you want to create a preset from scratch.
With very low FL pre amp multiplicators you can compare better the unprocessed version of a track with the results of the Multiband settings (especially if you want to use very aggressive settings for the MB in conjunction with spectral restorations of old music).
You can set of course very low FL pre amp multiplicators in a STS.
But it is not possible to adjust anything in the Limiting & Loudness sub-GUI (e.g. to find out if you want to use more clipping in LN/De-eSSer or more in the Multiband), because then that low FL pre amp multiplicator get lost.
So instead of a range from x0.5 to x1.5 for the FL pre amp multiplicator in the GUI it would be useful to have an expanded range:
x0.1 to x1.5 :!:
