PostPosted: Wed Feb 01, 2012 1:27 pm
I would know, how can i get a bass like this http://193.108.24.21:8000/fresh
PostPosted: Wed Feb 01, 2012 9:59 pm
i hear that mids and highly compressed highs dominates. And just in this moment after soft part in song, bass kicked into deep clip! which indicates on very slow attack for bass.
check this one viewtopic.php?f=3&t=4069
PostPosted: Mon Feb 06, 2012 9:48 pm
I want exactly the kick bass after the soft part in songs, but there isn't any kick bass in this settings... :(
PostPosted: Tue Feb 07, 2012 4:44 am
Can try my last preset, viewtopic.php?f=10&t=4017, but I think it should add a little low and extend the range of the Bass Boost.
Try and tell me what you think, I can with time, try to match that sound.
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue Feb 07, 2012 8:06 am
Sorry, but there isn't kick bass in it :(
I want especially the kick bass ;)
PostPosted: Tue Feb 07, 2012 6:12 pm
just set slower "down speed" for first 2 bands in multiband.
PostPosted: Tue Feb 07, 2012 6:23 pm
Well, i'm trying but unsucessfull for now...
I'm using the preset you gave me, but i can't make it
That's what i'm doing - http://oi41.tinypic.com/r7r4g5.jpg
Sorry for these stupid things, but i'm not really into setting up sound :(
PostPosted: Tue Feb 07, 2012 9:26 pm
This is an insanely FAST down speed! Set it *lower* than the other values!
PostPosted: Tue Feb 07, 2012 9:36 pm
I tried everything, but no result, can somebody do this and send me the preset, because i it looks like i can't do it myself :(
PostPosted: Thu Feb 09, 2012 8:21 pm
Will somebody help me?
Edit: Well, i did it! With so unsucessful tryings.... :mrgreen:
