PostPosted: Wed Jan 25, 2012 4:08 am
I'm trying to use the linux command line version but so far, everything I process just turns in to static...
The source file is:
/pub/archives/120121_221456_SRS001.wav: RIFF (little-endian) data, WAVE audio, Microsoft PCM, 24 bit, stereo 44100 Hz
I'm using of the config files pulled down from this forum:
TEN FM (Final) v2.sts
Is this happening because it's not a registered copy??? What am I doing wrong.
This is the tool I've been dreaming about for a long time. If I can get this to work, I'll be in heaven. SoX just wasn't cutting it.
My end goal is to mimic FM radio processing as much as possible and to automate the processing, hence the dream of having a command line tool.
Thanks
-jeremy
PostPosted: Thu Jan 26, 2012 1:05 am
Pasted from email:
Ah, the problem is clear then: Currently the command line version doesn't
read the WAV file header and just assumes it to be 16-bit stereo. No 24
bit :-)
So at least for now, you'll need to use 16 bit processing. :-(
Kind regards,
Hans
PostPosted: Thu Jan 26, 2012 1:15 am
Thanks. I classic style, I figured this out after I posted the message. It's actually in the help for the utility. I love this utility. It's exactly what I've been looking for.
Any presets out there that sound like KFI640 in Los Angeles? :-)
Thanks
PostPosted: Thu Jan 26, 2012 1:23 am
I'm in Europe, will try to tune in. :mrgreen:
