 Post subject: stereo tool with raduga
PostPosted: Fri Jan 13, 2012 4:03 pm
hello Have stereo tool that can use with Raduga..
Raduga mixer section Is it possible to load stereo tool..
I tried to install the mixer to stereo tool exe file, but it did not..
is the error message during the installation this is a winamp plugin..
Which version is compatible with Raduga radio automation..or how to be compatible with Raduga..
Have knows?
Waiting for your help
PostPosted: Sat Jan 14, 2012 2:12 am
Only solution is to install Stereo Tool Standalone And use VIrtual Audio Cable for Raduga's output.
or (i did't tryed)
To get some DX to VST plugin. Since Raduga supports DirectX, and Load VST Stereo Tool
PostPosted: Sun Jan 15, 2012 7:16 pm
firstly thank you for your response..
There are stand-alone version on my computer working part of the RDS and stereo..
but No music playing, no function..The display on the screen while playing music at all do not act in a...
rds, except with the stereo feature .. does not work in another function..
winamp version, all functions are working normally diagnosed when playing song..
stand-alone version part of the preset sts file load but there is no response..
virtual audio cable program is also installed on my computer I literally could not understand how it works with Raduga..
How could you make use of the VAC Do you have an illustrated narrative..
Waiting for your help..
thank you
PostPosted: Mon Jan 16, 2012 12:45 am
1. In Raduga, select "Virtual Audio Cable 1" as your output card.
2. In Stereo Tool, select "Virtual Audio Cable 1" as your input card.
That should do it.
PostPosted: Mon Jan 16, 2012 4:22 am
OK i found it "how".
1. You need StereoTool Standalone installed
2. You also need Virtual Audio Cable(s) installed
3. Go to Options in Raduga and in "Mixer" Option select "StereoTool.exe" from Stereo Tool standalone
4. In DirectX Plugins select Output Device Virtual Cable 1 -> Press OK
5. Press X while in Raduga to call StereoTool
6. In StereoTool Select Input/Sound Card Virtual Cable 1
done!
PS: In my opinion this is worst player for any purpose. For example, Winamp with few plugins is always better choice!
PostPosted: Thu Jan 19, 2012 5:21 pm
Thank you very much for your answers..I did like the picture in our
successful results.
2 audio delay is heard..2 audio delay setting for not here?
The excellent sound quality of Winamp. but winamp not radio automation program therefore pre-scheduled No properties.
of winamp It would be better if this feature..winamp schedule does not feature..
Raduga or zara radio with schedule most useful for me
a monthly or annual scheduled programs broadcast at any time..
