When starting ST it loads the last preset that was used, but does not show you the name of the preset. Would be handy to see it shown.
don't know if any settings have been changed since (loading).
IMO this is not really a problem.
Open menu
"RECENT PRESET FILES" and then you have the name, because the last loaded preset is on top of that list.
I would like to have a hidden INI option to have more than 10 entries in that list.
This would be very handy for situations when you want to compare a wider range of your (historic) presets (to be sure that your latest preset edits go in the right direction).
