PostPosted: Wed Aug 27, 2025 9:55 am
Im trying to get the CPU Value to be shown externally in our encoding platform.
what is the Enum value for the CPU status shown in the image?
thanks
PostPosted: Wed Aug 27, 2025 11:36 pm
Hi. Opening the inspector in Chrome (F12), selecting the element (upper left icon), and looking at the widget-id in the HTML, it appears to show 10665 as the value for CPU usage.
I hope this helps.
PostPosted: Thu Aug 28, 2025 12:51 am
Thanks MrKlorox
i started down this path aswell but that value returns an empty value
PostPosted: Thu Aug 28, 2025 3:25 am
Ah! I believe something to do with returning empty values (at least for errors) was solved in the latest couple of betas. Could you give one of those a try and see if this issue isn't already fixed? If not, I'll forward this Hans' way to figure out what's wrong.
PostPosted: Thu Aug 28, 2025 3:48 am
Where do i find the generic plugin dll for the betas?
PostPosted: Fri Aug 29, 2025 12:32 am
Ah, it's apparently not one of the builds that regularly go into the betas. I've pointed Hans this way and asked for the generic plugin to come out in the next beta. Hopefully, one happens soon.
PostPosted: Fri Aug 29, 2025 4:19 pm
I don't think that that's the bug that was fixed.
This is the latest version: https://download.thimeo.com/libStereoTo ... 71-007.zip
