 Post subject: RT+ Decoding issues
PostPosted: Tue Jul 01, 2025 11:55 am
I am having some issues with RT+ decoding both in RDS Spy and my car.
If there is a case when there are 2 RT + texts after eachother, sometimes the current RT+ text only shows the part of the previous message;
Sometimes, in between the sending of the next RT; the previous message is shown.
It happens in a 2024 Volkswagen Tiguan and a 2021 Hyundai Tucson.
Please see the screenshot below, is there any way to fix this? :D
 Post subject: Re: RT+ Decoding issues
PostPosted: Sun Sep 14, 2025 4:39 pm
Hi. Any updates?
PostPosted: Sun Sep 14, 2025 7:39 pm
Is the issue that you see "Cindy La" and it's cut off there, or that the wrong text is split into RT+ elements? (That 2nd thing looks like it's definitely a problem, the first shouldn't be possible so I don't know if you took the screenshot while that text was still loading?)
PostPosted: Sun Sep 14, 2025 8:03 pm
Hans, thanks for the quick response.
The issue is when the next message is beign sent, the RT+ tags are immediately sent, so for a second or two it applies to the previous message (only if the previous message had RT+)
I note that this did not occur in older ST versionw where <0D> is sent at the end.
Any ideas? :?:
