 Post subject: Titan Ultra
PostPosted: Sat May 24, 2025 3:31 pm
Created on 10.51 Beta
Trying to balance maximum loudness, clarity, stereo width, punch, bass depth, and artifact-free processing.
As always suggested input level at -6. Quality at 150%
File comment: Titan Ultra Beta
Titan Ultra Beta.sts [124.24 KiB]
Downloaded 607 times
 Post subject: Re: Titan Ultra
PostPosted: Fri May 30, 2025 10:26 am
G'day Grissle,
What speakers or headphones do you use?
just my thoughts on your preset
1) It pumps alot... your AGC is way to active
2) The high frequencies are to squashed
3) Its sounds really dense but the waveform doesnt look dense... too much compression!
Anyway just my 2 cents.
PostPosted: Fri May 30, 2025 3:07 pm
Thanks for the feedback.
Use AKG headphones and Paradigm speakers.
Needless to say, I agree it sounded somewhat nasty.
It's been re-tweaked with the update attached.
File comment: Titan Ultra 1.2
Titan Ultra 1.2.sts [133.25 KiB]
Downloaded 481 times
