 Post subject: Constance of sound
PostPosted: Sat Mar 05, 2011 7:48 pm
Hi
A new preset which increases bass, vocal frequencies and treble, with high volume.
cst loud (st).zip [2.84 KiB]
Downloaded 948 times
 Post subject: Re: Constance of sound
PostPosted: Sat Apr 16, 2011 9:59 pm
I like this preset a lot right now. I've been using it and it sounds pretty good. The only thing I added was the 15us compression for web radio. That gives it a nice, flat, non-muffled sound that I like.
Thanks.
PostPosted: Wed Apr 20, 2011 9:30 pm
You're welcome !!
If you want a more natural sound with this preset, use Replaygain when you're playing with Winamp (if you use Winamp). The best value is -8.0 dB.
