 Post subject: Bandpass bug
PostPosted: Fri Sep 06, 2024 6:50 pm
Hi!
I was performing some tests on my speakers and noticed a problem while testing at 35hz using this tool:
https://onlinetonegenerator.com/
I noticed bandpass is cutting off low frequencies even if I only use the lowpass filter.
I can hear the 35hz test tone with lowpass turned off, but as soon as i turn it on, no matter what settings I use, any sound around that frequency practically disappears.
 Post subject: Re: Bandpass bug
PostPosted: Fri Sep 06, 2024 8:47 pm
you sure HPF was at 0 when you testing ?
PostPosted: Fri Sep 06, 2024 8:59 pm
Yes, it was first set at 30hz, then I set it to off and there was zero difference, the bass only comes back after turning off bandpass itself.
PostPosted: Fri Sep 06, 2024 9:04 pm
Here is 35Hz tone with 35Hz HPF and LPF is ON.. all looks fine.
