Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Stereo Tool 10.40
PostPosted: Fri Sep 06, 2024 11:52 am
#metoo
Can you send me your full settings (.ini file)? I don't see it here so far...
Edit: I think I fixed it. These settings were not properly updated. Now they are. I'll run a beta build for testing this weekend.
PostPosted: Fri Sep 06, 2024 1:24 pm
I have added a "Reported issues" section to the opening post; once the important ones are solved we'll create a 10.41 version.
PostPosted: Mon Sep 09, 2024 3:05 pm
Hi.
Where Is the link on the website to download the Mac Vst3 version of 10.40. I can only see the vst 2 link.
Thanks
PostPosted: Sun Sep 22, 2024 9:39 am
I upgraded a ST-Enterprise setup and my input Axia stream numbers mostly got scrambled. Instance 1 and 5? were fine. The others all needed tweaking. I didn't think to check the instance configuration files in the user directory until after I had gotten it fixed.
Fixing that was made more difficult as my overview web page shows all the instances as unavailable. Thankfully the direct link [IP]:8001/instance[x]/ still works fine.
Perhaps my installation steps were incorrect? I stopped the service, ran the installer, restarted the service.
Running 10.40 as a service on Windows Server 2019
PostPosted: Sun Sep 22, 2024 10:20 pm
This is very scary. How were they "scrambled"? And the unavailable thing is weird as well, if they were working. This seems to point at a bug in the new version, but it's not something that we're aware of. And I don't know what could be causing it. Any more info would be very welcome.
PostPosted: Tue Sep 24, 2024 7:35 pm
All inputs are AES67 LiveWire, NIC is specified, device is either not detected or 0 (I still don't really understand what this is for, mine are either empty or have nonsense in the list) then my channel number. My channels numbers are approximately sequential in the 11xxx range.
Right after the upgrade, both the Device and the Channel numbers had things different than my notes. I have never used Device, so perhaps going from unconfigured to a new default sent us down a path? Some Livewire channels were lower numbers I saw a 3xx and high numbers 2xxxx, there didn't seem to be a pattern.
An example of my device pull down:
  • 2 (offline>)
    5303 SRC3 (offline?)
    20036 USY
    (not detected)
PostPosted: Wed Sep 25, 2024 4:45 am
Mac's VST is still broken on Adobe Audition and non-functional.
PostPosted: Wed Sep 25, 2024 11:03 am
VST2 or VST3?
PostPosted: Wed Sep 25, 2024 11:05 am
  • 2 (offline>)
    20036 USY
    (not detected)
Are the "unavailable" instances still unavailable? If so, could you send me your main .ini file plus the directory with the .ini files for all instances? That would be something like C:\Users\username\ST-Enterprise.ini plus C:\Users\username\ST-Enterprise.instances.
PostPosted: Thu Sep 26, 2024 12:53 am
VST2 or VST3?
The one on the site, VST2. Audition Audition 2024, Mac OS Monterey Intel. I tried the new beta, same problem.
