Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 3 Next
 Post subject: QuadBender
PostPosted: Sat Jun 08, 2024 10:33 pm
QuadBender
QuadBender_v0.33B.sts [439.17 KiB]
Downloaded 596 times
Very open and very edit-flexible preset.
Almost final version.
__________________________________________
QuadBender _Final.sts [439.2 KiB]
Downloaded 691 times
Final version.
- Fixed: sometime excessive lows on voices (speech detection)
* Be sure to load HD signal settings.
 Post subject: Re: QuadBender
PostPosted: Wed Jun 12, 2024 10:04 am
Nice preset mate
Good for mastering or just casual listening
Loud it is not, is clear and has presence.
Nice
PostPosted: Wed Jun 12, 2024 11:04 am
Indeed very editable and lite, i modified it for my second PC and got better sound and lower cpu usage than the preset i made specifically for it.
PostPosted: Thu Jun 13, 2024 10:03 pm
Very open and upfront. On FM sounds great!
The only thing I hear is that the bass volume increases on easier passages in music or vocals.
PostPosted: Fri Jun 14, 2024 1:13 am
Yea, using much thresh there, easy to adjust tho, just lower density for that band ;)
Forgot to mention, This preset uses my brand new, very custom, settings for clipper. It's bulletproof and super free from distortions.
PostPosted: Fri Jun 14, 2024 7:05 pm
Love it!
PostPosted: Sun Jun 23, 2024 5:01 pm
final.
PostPosted: Mon Jun 24, 2024 5:44 pm
I like it a lot, thank you...
PostPosted: Tue Jul 02, 2024 7:59 pm
Bojcha thnx, but where should I look? I'm totaly lost on new GUI :?
PostPosted: Tue Jul 02, 2024 10:21 pm
MB1 > levels > density
but anyways 'should' be better now as-is.
