PostPosted: Mon May 27, 2024 8:58 pm
I have an ESI Maya 44 USB+ sound card and when I use Wasapi output I hear it double as an echo, the input I use vac cable kernel streaming.
PostPosted: Tue May 28, 2024 2:11 pm
maby u use wasapi double
PostPosted: Tue May 28, 2024 6:37 pm
No, input is vac kernel output is maya usb+ wasapi realtek out wasapi is fine.
PostPosted: Tue May 28, 2024 11:07 pm
Doesn't that card support ASIO?
PostPosted: Tue May 28, 2024 11:41 pm
Yes it supports asio.
PostPosted: Wed May 29, 2024 12:14 am
Then I would output with ASIO instead of WASAPI. ASIO has direct control of the hardware and is potentially lower latency than any of the other Windows audio APIs like WASAPI, KS, or MME
