PostPosted: Mon May 20, 2024 4:16 pm
Hello,
We have bought a licence few weeks ago, but with this command line, in debian:
/usr/local/bin/stereo_tool_cmd_64 -k "<xxxx>" --r128 --r128-target 9.0 in.wav out.wav
we can randomly listen bips.
We can see in the first line THIMEO STEREO TOOL 10.30 CONSOLE APPLICATION - (C) THIMEO AUDIO TECHNOLOGY B.V., 2001-2024. Registered to "myname".
So it seems that the licence is valid.
Do we need to do something else?
Thanks,
PostPosted: Mon May 20, 2024 5:58 pm
yes you do ...go to license section and turn off all unlicensed features off...and will stop...
PostPosted: Mon May 20, 2024 11:58 pm
edit: Ignore my previous post. I completely misunderstood how the command line version worked. I've asked Hans for more clarity.
PostPosted: Tue May 21, 2024 1:42 am
Can you check the rest of the output? I would expect the following to be displayed:
Warning: License key does not cover all used features.
I've just verified that it shows that on my end when I enter a license key that doesn't contain all the used features. There are 2 things that cause beeps: Declipper and Delossifier. So I assume that one of those is enabled, but not part of your license.
(I can't find a license based on your email address so I can't check which license you have - please send me a PM with that info if this was insufficient information)
PostPosted: Tue May 21, 2024 5:03 pm
PM sent.
PostPosted: Thu May 23, 2024 10:41 am
Hello,
I found a solution.
Installation of the software. In one preset, I unchecked Declipper and Delossifier.
Save as.
Use this preset in the command line with the param "-s".
No more bip!
We can close this request.
Best,
