PostPosted: Mon Apr 08, 2024 7:43 pm
Hello guys, as i said in this topic: viewtopic.php?f=6&t=34076 I have problem with RDS time broadcasting after updating to the 10th version of Stereotool. In the 9th version i used this line:
1s:\\T2h\\:\\T02m\\:\\T02s/1s:\\T2h\\:\\T02m\\:\\T02s/1s:\\T2h\\:\\T02m\\:\\T02s
but for now it's just broadcasting this line as moving text instead of time. Is it bug or something changed from the 10th versions? (I tested 10.21 and 10.30)
PostPosted: Fri May 24, 2024 7:00 pm
I see double \\'s everywhere, those must be single \'s. At some point there has briefly been a bug in (I think) a beta version that could cause this to change.
PostPosted: Wed Jun 12, 2024 4:30 pm
A side issue that I noticed is that ST no longer seems to adhere to the specified number of seconds (eg. 7s:blahblah/7s:yadiyada). Whatever number of seconds is specified, each string is displayed for about 3,5 seconds. If no seconds are specified, then strings are displayed for about 9 or 10 seconds.
PostPosted: Thu Jun 13, 2024 6:21 pm
Oops. This broke when we added RDS2. It will be fixed in the next beta build (10.31 BETA021). All time values were sped up by a factor 4.
