PostPosted: Thu Apr 04, 2024 7:37 pm
Hi
I've switched to version 10.21 and it's a good product with few problems. I have a small problem. There is a setting for switching to a backup soundcard if the master card falls silent. But I cannot find the setting to set how long the silence should be before it reacts. It was there in 9.91 and I can't find it anymore.
Please advice.
PostPosted: Fri Apr 05, 2024 4:14 am
It's little hidden.
When you enable input2, then click on "input2" text (expand)
