PostPosted: Wed Jan 10, 2024 5:04 pm
While it's not blocking, or an actual bug, the .zip for the library version uses weird filenames such as:
libStereoTool_1020\lib\Linux\IntelAMD\64\libStereoTool_intel64.so
without an entry for the directory itself.
Assuming those .so will be unzipp'ed on Linux systems (though not only I guess), it might be nicer to name them a bit differently, or actually use directories in the archive?
Regards,
Gilou
PostPosted: Sat Jan 20, 2024 1:14 am
Hello Gilou,
How are you extracting the .zip file? I just tested it with the latest beta version and I get this, as expected:
unzip ./libStereoTool_BETA1021-006.zip
Archive: ./libStereoTool_BETA1021-006.zip
warning: ./libStereoTool_BETA1021-006.zip appears to use backslashes as path separators
inflating: libStereoTool_BETA1021-006/include/libStereoTool.h
inflating: libStereoTool_BETA1021-006/include/ParameterEnum.h
inflating: libStereoTool_BETA1021-006/lib/iOS/libStereoTool64.iOS.dylib
inflating: libStereoTool_BETA1021-006/lib/iOS/Simulator/libStereoTool64.iOS_Simulator.dylib
inflating: libStereoTool_BETA1021-006/lib/Linux/ARM/32/libStereoTool_arm32.so
inflating: libStereoTool_BETA1021-006/lib/Linux/ARM/64/libStereoTool_arm64.so
inflating: libStereoTool_BETA1021-006/lib/Linux/IntelAMD/32/libStereoToolX11_intel32.so
inflating: libStereoTool_BETA1021-006/lib/Linux/IntelAMD/32/libStereoTool_intel32.so
inflating: libStereoTool_BETA1021-006/lib/Linux/IntelAMD/64/libStereoToolX11_intel64.so
inflating: libStereoTool_BETA1021-006/lib/Linux/IntelAMD/64/libStereoTool_intel64.so
inflating: libStereoTool_BETA1021-006/lib/macOS/Universal/64/libStereoTool_64.dylib
inflating: libStereoTool_BETA1021-006/lib/Windows/32/libStereoTool_32.dll
inflating: libStereoTool_BETA1021-006/lib/Windows/32/libStereoTool_32.lib
inflating: libStereoTool_BETA1021-006/lib/Windows/64/libStereoTool_64.dll
inflating: libStereoTool_BETA1021-006/lib/Windows/64/libStereoTool_64.lib
So no backslashes.
PostPosted: Mon Jan 22, 2024 4:00 am
:D
