PostPosted: Sun Jan 07, 2024 7:57 pm
Apparenty searching for low latency output isn't allowed in the forum (too comon search term), so this is probably the 100 time someone posts this :) Sorry!
I am trying to get the lowest latency for use as jock pleasing, but am stuck at around 39ms total latency, which is not workable.
I have a WIndows 10 PC, i7-8700, 16GB PC with a RME HSDPe AES soundcard. Buffersize of the card is 128, and I use ASIO in Stereotool 10.12 BETA48. If I go below the +-20ms buffersize, I get a lot of dropouts. So when I'm around 24ms buffersize, it is OK. Unfortunately this is about 36ms total latency, with is not usable for jock pleasing.
I tried setting the buffersize of the card to 32, but this destroys my audio. 128 is the lowest that works OK.
Are there any things I can do to get the total latency around the 10ms?
Or do you really need the seperate STudio solution?
Thanks in advance for the help!
PostPosted: Sun Jan 07, 2024 11:00 pm
Ah, yeah. The built-in search needs 4 letters or more, which makes initialisms (like ITU, AGC, MB1, etc) very tough to search. To work around this, it's always good practice to use Google's site search for forums.stereotool.com.
https://www.google.com/search?q=site%3A ... eotool.com
Just type
site:forums.stereotool.com
before your query for the full power of google's syntax parsing.
PostPosted: Mon Jan 08, 2024 10:47 am
Yes, well, latency or output is more than 3 characters long :)
Anyway, lets discuss the issue :)
