 Post subject: Stereotool and VMix vst3
PostPosted: Fri Sep 15, 2023 12:37 pm
Hello
I have a valid license for stereotool FM Professional + Declipper, the activation for stand alone is ok *works fine ), but in vmix as vst3 it says no: vst plugin used whitout license. where is the problem?
PostPosted: Tue Sep 19, 2023 5:13 pm
According to Hans, this is a mistake and it shouldn't affect anything. It for sure will be fixed. The devs were at a broadcasting convention over the weekend, so they're just now able to approach this.
Hello!
I have a valid license FM Professional+ Declipper whose license does not work as a plugin in vmix. As a standalone application, the license works ok without problems. When I install the plugin in vmix it says: vst plugin use whitout license.
What would be the problem, why doesn't it work?
I think I made a booboo. I added that message a few weeks ago (the VST plugin requires *some* license to be present, and there was no message on screen that warned if you didn't have any but also weren't using features that are normally paid) but I heard from others (haven't had time to check yet due to IBC) that this message now pops up even if it's registered. If you see that things are registered on the registation page, you can *probably* ignore this message for now. (If there are no beeps or other messages after a few minutes, everything is ok).
