Post new topic  Reply to topic  [ 707 posts ]  Go to page Previous 140 41 42 43 4471 Next
PostPosted: Mon May 01, 2023 6:11 pm
We have worked on things last week, but nothing that was enough to warrant a new build. I think I'll run one tonight, indeed.
Time zone difference was 9 hours, not THAT bad. But after close to 2 weeks of Las Vegas (which is always a lot of fun!) it's definitely nice to relax a bit. :)
PostPosted: Thu May 04, 2023 11:39 am
It took a bit longer (the build pc was unstable and kept rebooting, I hope that that's fixed now), but there's a new beta version, BETA071. See opening post for change log.
PostPosted: Thu May 04, 2023 10:27 pm
Is there any lead as to what causes the behavior of popping up the window behind other apps?
PostPosted: Mon May 08, 2023 5:52 pm
Delossifier requires the difference to be enabled and then disabled to show it's working. I don't know if this is just GUI or actual function.
PostPosted: Tue May 09, 2023 10:44 am
It takes a few seconds for it to kick in, so I think that that's what you saw.
Thanks for the reminder, not yet.
PostPosted: Thu May 11, 2023 11:17 am
Since Beta066 I briefly get a message not responding when I load a preset from my PC
PostPosted: Thu May 11, 2023 11:24 am
How long does loading a preset take? It should return almost immediately. On my pc I don't notice any delay at all, so it probably takes less than 100 ms or so. This "not responding" message usually pops up when something blocks for at least 10 seconds or so.
PostPosted: Thu May 11, 2023 11:39 am
It takes 12 seconds
Edit: It is only after a factory reset of preset and exit from ST and reopen again and then load a preset again
PostPosted: Thu May 11, 2023 5:26 pm
It takes 12 seconds
It's instantaneous here, also after a factory reset. Are you loading an external preset file? If so, could you send me that file so I can try to reproduce it here?
PostPosted: Thu May 11, 2023 7:02 pm
It takes 12 seconds
I have sent you a mail with the preset and explanation
