 Post subject: Few things
PostPosted: Thu Sep 15, 2022 8:10 pm
- SideChain PEQ for Pre-Limiter. Can be nicely used for highs to protect rest of sound from highs, like loud 'S' or any other sound. (tested with current and difference is HUGE)
- Possibility to place 'Bass Shape' in "Advanced clipper", to be placed before "Secondary bass clipper" in "Advanced Clipper".
- Possibility to place "Bass Clipper" before "Secondary bass clipper" in "Advanced Clipper"
- Fix for Advanced clipper, "Reduce Bass for mids". This filter detects mids from ~500-5000Hz it need to go atleast from 300Hz, with some nice slope, nothing (from configurable options) protect tones from ~200-500Hz, so bass is around 1-2dB louder then it should when this tones are present causing distortion in voices around that freq.
- Fix for "Protects highs above" in Clipper>Highs. Slider goes from 1500Hz but setting it there is more like 3kHz.
- Reminder for this viewtopic.php?f=16&t=29832
 Post subject: Re: Few things
PostPosted: Fri Sep 16, 2022 1:30 pm
Agreed about this. Seems like it could be a good way to combine/mix sources into one input for ST at low latency if combined with other Voicemeeter apps.
