PostPosted: Tue Sep 06, 2022 5:35 pm
Hello everyone.
I am using RVR Radio transmitter. There are 10k Ohm and 50 Ohm switches in the MPX input impedance part. Which one should you choose?
PostPosted: Tue Sep 06, 2022 6:51 pm
Hello everyone.
The one that is similar to you MPX output. Usually it's 10kOhm.
PostPosted: Wed Sep 07, 2022 12:52 pm
Hello everyone.
Thank you for your reply.
I set it to 10K Ohm. So what do these settings mean?
PostPosted: Fri Sep 09, 2022 9:32 pm
its probably your cable and Ariel resistance.
