 Post subject: Weird GUI artifact...
PostPosted: Sun Jul 31, 2022 4:44 am
Hi all,
I've just noticed some overlap on either side of the 19kHz pilot signal and was wondering whether it's normal, and if not, what can be done to remove it?
The low pass to the TX is set at 16.1kHz in ST, so I would have thought a 2.9kHz buffer would have been enough.
https://imgur.com/a/oX2iIli
Cheers,
Baldrick
PostPosted: Wed Aug 03, 2022 10:04 pm
Bump...
PostPosted: Thu Aug 04, 2022 7:36 am
Hi all,
Cheers,
Baldrick
Never seen that. Where’s your quality slider at?
PostPosted: Sun Aug 07, 2022 7:38 am
Quality slider?
PostPosted: Fri Aug 12, 2022 11:24 am
Ah. This is a GUI issue that I haven't been able to figure out..... It happens with certain combinations of settings. It seems to be analyzing audio that's not yet generated. This doesn't affect the actual signal.
PostPosted: Mon Aug 15, 2022 4:36 am
Thanks for the clarification Hans.
