 Post subject: LOGIN / PASSWORD
PostPosted: Mon Jun 06, 2022 7:45 pm
Hello. for some days stereo tools asks me for a login to be able to access the parameters of stereotools. I have never set up the login and therefore have no password. can you tell me what i have to do in order to be able to delete this login parameter in order to be able to access my stereotools parameters again. thank you
 Post subject: Re: LOGIN / PASSWORD
PostPosted: Mon Jun 06, 2022 11:00 pm
Check "%USERPROFILE%\stereo_tool.ini"
Look at around line 6500 for the "Password protection enabled=" setting, and make sure it reads
Password protection enabled=0
