PostPosted: Mon May 23, 2022 9:06 pm
Audio::calc_real_fft_mixed2mono_outofplace not optimized
Audio::split_l_r not optimized
Audio::calc_real_fft not optimized
Audio::calc_inverse_real_fft not optimized
Audio::combine_l_r not optimized
I saw the above in the log - is this anything to worry about?
PostPosted: Thu Oct 13, 2022 11:48 am
No, this is a note to myself that I haven't written NEON code for ARM CPU's yet. Actually.. it might not be such a bad idea to do that now, with all the new ARM programs that we're releasing.
PostPosted: Thu Oct 13, 2022 1:14 pm
Ah! And there are instructions specifically for what I want to do here! (VZIPQ.32 and VUZPQ.32)
https://community.arm.com/arm-community ... ng-vectors
PostPosted: Thu Oct 13, 2022 8:09 pm
Partially done... 4 gone, 3 to go.
Edit: 6 and 1 now.
Edit: No, 6 and 0. That last one was never used anyway.
PostPosted: Sat Nov 05, 2022 11:24 am
Edit: 6 and 1 now.
Hi Hans, thank you so much for tackling this one. It can never be a bad thing to further optimise the code for the ARM CPUs, particularly as resources aren't as plentiful as you'd find on a more power hungry solution like Intel based PCs and such like.
I look forward to seeing this completed :-)
